Introducción
In this guide, we will show you how to remove and replace the Memory Module.
Partes
No se requieren partes.
  1. Slide the battery release latch to the unlock position.
    • Slide the battery release latch to the unlock position.
  2. Slide the other battery release latch to the unlock position.
    • Slide the other battery release latch to the unlock position.
  3. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the screws that secure the base cover to the computer.
    • Remove the screws that secure the base cover to the computer.
  6. Lift up the base cover and remove it from the computer.
    • Lift up the base cover and remove it from the computer.
  7. Push apart the memory retention clips to release the memory module.
    • Push apart the memory retention clips to release the memory module.
  8. Remove the memory module from its connector on the system board.
    • Remove the memory module from its connector on the system board.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 22
