Introducción
In this guide, we will show you how to remove and replace the Memory Module.
Partes
No se requieren partes.
  1. Slide the battery lock to the open position.
    • Slide the battery lock to the open position.
    • Slide the battery release latch to the open position.
    • Slide the battery out of the battery bay.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the two screws that secure the memory cover, then remove the cover and set it aside.
    • Remove the two screws that secure the memory cover, then remove the cover and set it aside.
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Linea de Meta
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 18
