Saltar al contenido principal
Introducción
This guide will instruct you on how to remove the Wi-Fi card from the Dell Vostro 1700 laptop. The Wi-Fi card controls all of the wireless internet functionality of the laptop.
Partes
No se especificaron partes.
  1. Remove the two Phillips #1 screws from the Wi-Fi card cover on the bottom of the laptop. Remove the two Phillips #1 screws from the Wi-Fi card cover on the bottom of the laptop.
    • Remove the two Phillips #1 screws from the Wi-Fi card cover on the bottom of the laptop.
  2. Lift up on the cover and remove it. Lift up on the cover and remove it. Lift up on the cover and remove it.
    • Lift up on the cover and remove it.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Use the spudger to lift the small wires connecting to the Wi-Fi card. Use the spudger to lift the small wires connecting to the Wi-Fi card. Use the spudger to lift the small wires connecting to the Wi-Fi card.
    • Use the spudger to lift the small wires connecting to the Wi-Fi card.
  5. Use your thumbs to push the retaining clips upward to release the card. Use your thumbs to push the retaining clips upward to release the card.
    • Use your thumbs to push the retaining clips upward to release the card.
  6. Pull the card outward and then upward to remove it from the slot. Pull the card outward and then upward to remove it from the slot. Pull the card outward and then upward to remove it from the slot.
    • Pull the card outward and then upward to remove it from the slot.
Conclusión
Nathan Valm
Miembro Desde 20/03/18
678 Reputación
5 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 2
Todo El Tiempo: 25
