Saltar al contenido principal
Dell Vostro 1700 RAM Replacement
Qué necesitas
  1. Dell Vostro 1700 RAM Replacement, Keyboard: paso 1, imagen 1 de 3 Dell Vostro 1700 RAM Replacement, Keyboard: paso 1, imagen 2 de 3 Dell Vostro 1700 RAM Replacement, Keyboard: paso 1, imagen 3 de 3
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: paso 2, imagen 1 de 1
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: paso 3, imagen 1 de 2 Dell Vostro 1700 RAM Replacement: paso 3, imagen 2 de 2
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: paso 4, imagen 1 de 2 Dell Vostro 1700 RAM Replacement: paso 4, imagen 2 de 2
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: paso 5, imagen 1 de 2 Dell Vostro 1700 RAM Replacement: paso 5, imagen 2 de 2
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: paso 6, imagen 1 de 3 Dell Vostro 1700 RAM Replacement, RAM: paso 6, imagen 2 de 3 Dell Vostro 1700 RAM Replacement, RAM: paso 6, imagen 3 de 3
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: paso 7, imagen 1 de 3 Dell Vostro 1700 RAM Replacement: paso 7, imagen 2 de 3 Dell Vostro 1700 RAM Replacement: paso 7, imagen 3 de 3
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: paso 8, imagen 1 de 3 Dell Vostro 1700 RAM Replacement: paso 8, imagen 2 de 3 Dell Vostro 1700 RAM Replacement: paso 8, imagen 3 de 3
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: paso 9, imagen 1 de 2 Dell Vostro 1700 RAM Replacement: paso 9, imagen 2 de 2
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: paso 10, imagen 1 de 3 Dell Vostro 1700 RAM Replacement: paso 10, imagen 2 de 3 Dell Vostro 1700 RAM Replacement: paso 10, imagen 3 de 3
    • Lift the RAM chip up and out of the slot.
Conclusión
2 personas más completaron esta guía.
Nathan Valm
Miembro Desde 03/20/18
735 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,012
