Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Memory Module.
Partes
No se especificaron partes.
  1. Slide and click the battery release latches to keep them open.
    • Slide and click the battery release latches to keep them open.
    • Slide the battery out of the bay.
  2. Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Ease the hinge cover up, moving from right to left, and remove it.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the four screws at the top of the keyboard.
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
    • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
    • Lift and remove the keyboard.
  5. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the memory module from the connector.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 21
