Saltar al contenido principal
Dell Vostro 1500 Keyboard Replacement
Qué necesitas
  1. Dell Vostro 1500 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: paso 2, imagen 1 de 1
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: paso 3, imagen 1 de 1
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: paso 5, imagen 2 de 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: paso 5, imagen 3 de 3
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Vostro 1500 Keyboard Replacement: paso 6, imagen 2 de 2
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Vostro 1500 Keyboard Replacement: paso 7, imagen 2 de 2
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: paso 8, imagen 1 de 3 Dell Vostro 1500 Keyboard Replacement: paso 8, imagen 2 de 3 Dell Vostro 1500 Keyboard Replacement: paso 8, imagen 3 de 3
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: paso 9, imagen 1 de 1
    • Pull the connector toward the screen.
Conclusión
2 personas más completaron esta guía.
Daniel Roskuski
Miembro Desde 10/19/16
219 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-3, Catania Fall 2016 Miembro de UMass Dartmouth, Team 1-3, Catania Fall 2016
UMASSD-CATANIA-F16S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,024
