Saltar al contenido principal
Partes
No se especificaron partes.
  1. Slide the release latch to release the battery [1].
    • Slide the release latch to release the battery [1].
    • Remove the battery from the computer [2].
  2. Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  3. Disconnect the keyboard cable from the system board.
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  6. Remove the screws that secure the base cover to the computer
    • Remove the screws that secure the base cover to the computer
  7. Pry the edges of the base cover [1].
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Disconnect the hard drive cable from the connector on the system board [1].
    • Disconnect the hard drive cable from the connector on the system board [1].
    • Remove the screws that secure the hard drive assembly to the computer [2].
    • Lift the hard drive assembly away from the computer [3].
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 10
Últimos 7 Días: 58
Últimos 30 Días: 251
Todo El Tiempo: 2,361
