Partes
No se requieren partes.
  1. Slide the release latch to unlock the battery [1].
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Remove the screw that secures the optical drive to the computer [1].
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Release the keyboard by prying on the keyboard release tabs by using a scribe.
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  6. Disconnect the keyboard cable from the system board [1].
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  7. Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  8. Remove the screws that secure the base cover to the computer [1].
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  9. Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 44
