Saltar al contenido principal
Dell Vostro 1400 Hard Drive Replacement
Qué necesitas
  1. Dell Vostro 1400 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 Hard Drive Replacement: paso 3, imagen 1 de 2 Dell Vostro 1400 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Dell Vostro 1400 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Please ensure that your device is turned off and everything is unplugged before working on it.
    • Unscrew both screws on the hard drive panel until the panel is able to be removed.
    • The screws will not come off of the panel.
    • Once screws have been loosened, remove the panel from the laptop.
  5. Dell Vostro 1400 Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
Conclusión
2 personas más completaron esta guía.
David Hogg
Miembro Desde 03/20/17
727 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 703
