Saltar al contenido principal
Dell Vostro 1320 Screen Replacement
Qué necesitas
  1. Dell Vostro 1320 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Take screw covers off with a metal spudger
  2. Dell Vostro 1320 Screen Replacement: paso 2, imagen 1 de 1
    • Take the six screws out with the bit driver.
  3. Dell Vostro 1320 Screen Replacement: paso 3, imagen 1 de 2 Dell Vostro 1320 Screen Replacement: paso 3, imagen 2 de 2
    • Pop the black plastic panel off with the metal spudger. There are three spots where you should leverage it so that the panel does not break.
  4. Dell Vostro 1320 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the plug on the bottom of the screen.
  5. Dell Vostro 1320 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the two screws on the bottom of the computer screen.
  6. Dell Vostro 1320 Screen Replacement: paso 6, imagen 1 de 1
    • Remove the tape and the LCD plug/connector from the back of the screen.
  7. Dell Vostro 1320 Screen Replacement: paso 7, imagen 1 de 2 Dell Vostro 1320 Screen Replacement: paso 7, imagen 2 de 2
    • Remove the three screws on the left and right of the screen.
  8. Dell Vostro 1320 Screen Replacement: paso 8, imagen 1 de 1
    • Remove the screen from the metal side frames.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 865
