Partes
No se requieren partes.
  1. Slide the battery latches apart while at the same time slipping your forefingers into the groove at the center of the battery and pushing outward to disengage the battery from the computer. Lift the battery from the computer.
    • Slide the battery latches apart while at the same time slipping your forefingers into the groove at the center of the battery and pushing outward to disengage the battery from the computer.
    • Lift the battery from the computer.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the six screws that secure the access panel to the computer. Remove the access panel from the computer.
    • Remove the six screws that secure the access panel to the computer.
    • Remove the access panel from the computer.
  4. Remove the four screws that secure the hard drive assembly to the computer. Pull the plastic tab toward the opposite end of the hard drive assembly to disengage the hard drive interposer from the connector on the system board, then lift the hard drive assembly from the computer.
    • Remove the four screws that secure the hard drive assembly to the computer.
    • Pull the plastic tab toward the opposite end of the hard drive assembly to disengage the hard drive interposer from the connector on the system board, then lift the hard drive assembly from the computer.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 31
