Partes
No se requieren partes.
  1. Slide the battery latches apart to the unlock position. Lift the battery from the computer.
    • Slide the battery latches apart to the unlock position.
    • Lift the battery from the computer.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the six screws that secure the access panel to the computer. Remove the access panel from the computer.
    • Remove the six screws that secure the access panel to the computer.
    • Remove the access panel from the computer.
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up. Slide the memory module from its socket and remove the module from the computer.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Slide the memory module from its socket and remove the module from the computer.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 23
