Partes
No se requieren partes.
  1. Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
    • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. loosen the captive screws on the memory module cover, and then remove the memory module cover.
    • loosen the captive screws on the memory module cover, and then remove the memory module cover.
  4. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 28
