Saltar al contenido principal
Dell Venue 8 7840 Screen Replacement
Qué necesitas
  1. Dell Venue 8 7840 Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: paso 2, imagen 1 de 1
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: paso 3, imagen 1 de 1
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: paso 4, imagen 1 de 1
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: paso 5, imagen 1 de 1
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: paso 6, imagen 1 de 1
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: paso 7, imagen 1 de 1
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: paso 8, imagen 1 de 1
    • Disconnect the connector from the tablet.
Conclusión
Equipo
USF Tampa, Team 6-5, Remmell Fall 2016 Miembro de USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Miembros
6 Guías creadas
3 comentarios
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - Contestar
Where can I find a replacement screen for this device?
Karim Mohamed - Contestar
Is the OLED connected with EDP 30=pin FPC?
Ron King - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 1,399
