Saltar al contenido principal
Dell Venue 7 Rear Facing Camera Replacement
Qué necesitas
  1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: paso 1, imagen 1 de 2 Dell Venue 7 Rear Facing Camera Replacement, Rear Case: paso 1, imagen 2 de 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Rear Facing Camera Replacement, Battery: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Rear Facing Camera Replacement: paso 3, imagen 1 de 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: paso 4, imagen 1 de 1
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Rear Facing Camera Replacement: paso 5, imagen 1 de 1
    • Remove the camera from the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 11-4, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 473
