Saltar al contenido principal
Dell Venue 7 Battery Replacement
Qué necesitas
  1. Dell Venue 7 Battery Replacement, Rear Case: paso 1, imagen 1 de 2 Dell Venue 7 Battery Replacement, Rear Case: paso 1, imagen 2 de 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Battery Replacement, Battery: paso 2, imagen 1 de 1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
Conclusión
chaveza
Miembro Desde 01/20/15
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 11-4, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Miembros
10 Guías creadas
4 comentarios
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Contestar
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 7,366
