Introducción
If you typically find yourself using the USB Port of your Dell Venue 11 Pro, then the port on your device might wear out sooner than you think. Fortunately, we've made a relatively easy guide you can follow to replace your USB Port. First, you will need to follow the battery and frame replacement guides before working on the USB port replacement.
Qué necesitas
Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
7 personas más completaron esta guía.
