Saltar al contenido principal
Dell Venue 11 Pro Frame Replacement
Qué necesitas
  1. Dell Venue 11 Pro Frame Replacement, Battery: paso 1, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement, Battery: paso 1, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement, Battery: paso 1, imagen 3 de 3
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro Frame Replacement: paso 2, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement: paso 2, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement: paso 2, imagen 3 de 3
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro Frame Replacement, Frame: paso 3, imagen 1 de 2 Dell Venue 11 Pro Frame Replacement, Frame: paso 3, imagen 2 de 2
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro Frame Replacement: paso 4, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement: paso 4, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement: paso 4, imagen 3 de 3
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro Frame Replacement: paso 5, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement: paso 5, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement: paso 5, imagen 3 de 3
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro Frame Replacement: paso 6, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement: paso 6, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement: paso 6, imagen 3 de 3
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro Frame Replacement: paso 7, imagen 1 de 1
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro Frame Replacement: paso 8, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement: paso 8, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement: paso 8, imagen 3 de 3
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro Frame Replacement: paso 9, imagen 1 de 3 Dell Venue 11 Pro Frame Replacement: paso 9, imagen 2 de 3 Dell Venue 11 Pro Frame Replacement: paso 9, imagen 3 de 3
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
Conclusión
2 personas más completaron esta guía.
Tom Nguyen
Miembro Desde 09/28/17
1,277 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S3-G1, Nance Fall 2017 Miembro de USF Tampa, Team S3-G1, Nance Fall 2017
USFT-NANCE-F17S3G1
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 24
Todo El Tiempo: 1,622
