Saltar al contenido principal
Dell VRP100 Screen Replacement
Qué necesitas
  1. Dell VRP100 Screen Replacement, Cover Panel: paso 1, imagen 1 de 3 Dell VRP100 Screen Replacement, Cover Panel: paso 1, imagen 2 de 3 Dell VRP100 Screen Replacement, Cover Panel: paso 1, imagen 3 de 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Screen Replacement: paso 3, imagen 1 de 3 Dell VRP100 Screen Replacement: paso 3, imagen 2 de 3 Dell VRP100 Screen Replacement: paso 3, imagen 3 de 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Screen Replacement: paso 4, imagen 1 de 3 Dell VRP100 Screen Replacement: paso 4, imagen 2 de 3 Dell VRP100 Screen Replacement: paso 4, imagen 3 de 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Screen Replacement, Screen: paso 5, imagen 1 de 3 Dell VRP100 Screen Replacement, Screen: paso 5, imagen 2 de 3 Dell VRP100 Screen Replacement, Screen: paso 5, imagen 3 de 3
    • Remove the four 2.5 mm PH000 screws by rotating counter-clockwise.
    • Separate the lenses from the motherboard panel.
  6. Dell VRP100 Screen Replacement: paso 6, imagen 1 de 2 Dell VRP100 Screen Replacement: paso 6, imagen 2 de 2
    • Take off the tape using the blunt nosed tweezers to disconnect the flat-topped connector from the motherboard.
    • The screen is attached to the motherboard using an adhesive.
  7. Dell VRP100 Screen Replacement: paso 7, imagen 1 de 3 Dell VRP100 Screen Replacement: paso 7, imagen 2 de 3 Dell VRP100 Screen Replacement: paso 7, imagen 3 de 3
    • Lift the yellow tape with tweezers.
    • Remove the ribbon cable from the screen to the motherboard with tweezers.
  8. Dell VRP100 Screen Replacement: paso 8, imagen 1 de 3 Dell VRP100 Screen Replacement: paso 8, imagen 2 de 3 Dell VRP100 Screen Replacement: paso 8, imagen 3 de 3
    • Remove the six 3.4mm PH000 screws by rotating counter-clockwise connecting the back panel to the screen.
    • Remove the back panel from the screen by carefully pulling apart the two.
  9. Dell VRP100 Screen Replacement: paso 9, imagen 1 de 3 Dell VRP100 Screen Replacement: paso 9, imagen 2 de 3 Dell VRP100 Screen Replacement: paso 9, imagen 3 de 3
    • Peel away the screen with both hands.
    • A plastic opening tool may be required for removing the screen.
    • Adhesive may need to be reapplied during the rebuild.
Conclusión
Lauren Monzon
Miembro Desde 10/08/18
217 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G1, White Fall 2018 Miembro de Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 889
