Saltar al contenido principal
Dell VRP100 Lens Replacement
Qué necesitas
  1. Dell VRP100 Lens Replacement, Cover Panel: paso 1, imagen 1 de 3 Dell VRP100 Lens Replacement, Cover Panel: paso 1, imagen 2 de 3 Dell VRP100 Lens Replacement, Cover Panel: paso 1, imagen 3 de 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Lens Replacement: paso 2, imagen 1 de 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Lens Replacement: paso 3, imagen 1 de 3 Dell VRP100 Lens Replacement: paso 3, imagen 2 de 3 Dell VRP100 Lens Replacement: paso 3, imagen 3 de 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Lens Replacement: paso 4, imagen 1 de 3 Dell VRP100 Lens Replacement: paso 4, imagen 2 de 3 Dell VRP100 Lens Replacement: paso 4, imagen 3 de 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Lens Replacement, Lens: paso 5, imagen 1 de 2 Dell VRP100 Lens Replacement, Lens: paso 5, imagen 2 de 2
    • Deattach the black cover from the lens with a metal spudger.
    • This will “click” back into place during replacement.
  6. Dell VRP100 Lens Replacement: paso 6, imagen 1 de 3 Dell VRP100 Lens Replacement: paso 6, imagen 2 de 3 Dell VRP100 Lens Replacement: paso 6, imagen 3 de 3
    • Gently insert the metal spudger between the lens and the lens casing.
    • Rotate the spudger around the exterior of the lens and lens housing, separating them.
    • The lens is held in place with an adhesive that will have to be applied during reassembly.
  7. Dell VRP100 Lens Replacement: paso 7, imagen 1 de 1
    • Holding the lens around the outside, gently lift it out of its housing.
Conclusión
Una persona más ha completado esta guía.
Chris Grabow
Miembro Desde 10/08/18
285 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G1, White Fall 2018 Miembro de Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 17
Todo El Tiempo: 791
