Saltar al contenido principal
Dell VRP100 Auxiliary Cord Replacement
Qué necesitas
  1. Dell VRP100 Auxiliary Cord Replacement, Cover Panel: paso 1, imagen 1 de 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: paso 1, imagen 2 de 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: paso 1, imagen 3 de 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Auxiliary Cord Replacement: paso 2, imagen 1 de 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Auxiliary Cord Replacement: paso 3, imagen 1 de 3 Dell VRP100 Auxiliary Cord Replacement: paso 3, imagen 2 de 3 Dell VRP100 Auxiliary Cord Replacement: paso 3, imagen 3 de 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Auxiliary Cord Replacement: paso 4, imagen 1 de 3 Dell VRP100 Auxiliary Cord Replacement: paso 4, imagen 2 de 3 Dell VRP100 Auxiliary Cord Replacement: paso 4, imagen 3 de 3
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: paso 5, imagen 1 de 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: paso 5, imagen 2 de 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: paso 5, imagen 3 de 3
    • Separate the external connector of the auxiliary cord.
    • A spudger may be needed to separate the connector.
  6. Dell VRP100 Auxiliary Cord Replacement: paso 6, imagen 1 de 2 Dell VRP100 Auxiliary Cord Replacement: paso 6, imagen 2 de 2
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  7. Dell VRP100 Auxiliary Cord Replacement: paso 7, imagen 1 de 3 Dell VRP100 Auxiliary Cord Replacement: paso 7, imagen 2 de 3 Dell VRP100 Auxiliary Cord Replacement: paso 7, imagen 3 de 3
    • In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
    • Carefully pull out the bundled cable connectors.
Conclusión
Una persona más ha completado esta guía.
Chris Grabow
Miembro Desde 10/08/18
285 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S17-G1, White Fall 2018 Miembro de Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Miembros
12 Guías creadas
Un comentario
Hello, where i can buy the aux cable?
Domenico Rescigno - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 674
