Saltar al contenido principal
Introducción
Do you have a sticky joystick? Fix it here! Dirt buildup and long-term use cause sticky joysticks. For this guide, you will need a plastic opening tool.
Partes
No se especificaron partes.
  1. Dell VRC100-R Joystick Replacement, Joystick: paso 1, imagen 1 de 3 Dell VRC100-R Joystick Replacement, Joystick: paso 1, imagen 2 de 3 Dell VRC100-R Joystick Replacement, Joystick: paso 1, imagen 3 de 3
    • Hold the joystick down with your left thumb to make space for the plastic opening tool.
    • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
    • Slide the plastic opening tool around the perimeter until you can lift the front panel.
    • You may hear a popping noise when you pry off the front panel.
  2. Dell VRC100-R Joystick Replacement: paso 2, imagen 1 de 2 Dell VRC100-R Joystick Replacement: paso 2, imagen 2 de 2
    • Grab the joystick and pull away from the controller to remove it.
Conclusión
Kenneth Liu
Miembro Desde 18/04/18
169 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G3, Livingston Spring 2018 Miembro de Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 535
