Saltar al contenido principal
Dell VRC100-R Battery Replacement
  1. Dell VRC100-R Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell VRC100-R Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell VRC100-R Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
    • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
    • Slide the cover off and separate it from the controller.
  2. Dell VRC100-R Battery Replacement: paso 2, imagen 1 de 2 Dell VRC100-R Battery Replacement: paso 2, imagen 2 de 2
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
Conclusión
Kenneth Liu
Miembro Desde 04/18/18
169 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G3, Livingston Spring 2018 Miembro de Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Miembros
5 Guías creadas
Un comentario
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 716
