Saltar al contenido principal
Partes
No se especificaron partes.
  1. Slide the battery release latch to the side. {2}
    • Slide the battery release latch to the side. {2}
    • Slide the battery out of the battery bay. {1}
  2. Loosen the ten captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • Loosen the ten captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the three screws securing the hard drive assembly to the computer base.
    • Remove the three screws securing the hard drive assembly to the computer base.
    • Pull the blue pull-tab to disconnect the hard drive assembly from the system board connector.
    • Lift the hard drive assembly out of the computer base.
  5. NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging .
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging .
    • Remove the four screws that secure the hard drive bracket to the hard drive and remove the bracket.
  6. Pull the interposer to disconnect it from the hard drive.
    • Pull the interposer to disconnect it from the hard drive.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 45
