Partes
No se requieren partes.
  1. Slide the battery release latch until it clicks into place.
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the six screws that secure the base cover to the computer base.
    • Remove the six screws that secure the base cover to the computer base.
    • Lift the base cover off the computer at an angle as shown in the following illustration.
  4. Remove the four screws that secure the hard drive assembly to the computer base. Using the pull-tab, slide the hard drive towards the left to disconnect the hard drive assembly from the connector on the system board. Lift the hard drive assembly out of the computer base.
    • Remove the four screws that secure the hard drive assembly to the computer base.
    • Using the pull-tab, slide the hard drive towards the left to disconnect the hard drive assembly from the connector on the system board.
    • Lift the hard drive assembly out of the computer base.
    • Remove the four screws that secure the hard drive cage to the hard drive.
    • Lift the hard drive off the hard drive cage.
    • Pull the interposer to disconnect it from the hard drive.
Conclusión
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 15
Todo El Tiempo: 105
