Saltar al contenido principal
Dell Studio 1737 Hard Drive Replacement
Qué necesitas
  1. Dell Studio 1737 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Dell Studio 1737 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Hard Drive Replacement, Back Panel: paso 2, imagen 1 de 3 Dell Studio 1737 Hard Drive Replacement, Back Panel: paso 2, imagen 2 de 3 Dell Studio 1737 Hard Drive Replacement, Back Panel: paso 2, imagen 3 de 3
    • Unscrew the 8 Phillips head screws marked in the photo.
    • Even when the screws are fully detached, they will not come out of the panel.
    • Use a plastic opening tool to pry the panel away from the laptop body.
    • Lift the panel up and away.
  3. Dell Studio 1737 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Dell Studio 1737 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Detach Hard drive from SATA connector.
    • Pull hard drive up and out pulling connector out of the way.
    • NOTE: your hard drive may be attached by screws or a bracket. This device had the hard drive just placed under the casing.
Conclusión
3 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,708
