Saltar al contenido principal
Dell Studio 1555 RAM Replacement
Qué necesitas
  1. Dell Studio 1555 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 RAM Replacement: paso 2, imagen 1 de 3 Dell Studio 1555 RAM Replacement: paso 2, imagen 2 de 3 Dell Studio 1555 RAM Replacement: paso 2, imagen 3 de 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 RAM Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 RAM Replacement, Back Panel: paso 4, imagen 1 de 3 Dell Studio 1555 RAM Replacement, Back Panel: paso 4, imagen 2 de 3 Dell Studio 1555 RAM Replacement, Back Panel: paso 4, imagen 3 de 3
    • Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
    • The three 5mm screws will stay in place on the back panel.
  5. Dell Studio 1555 RAM Replacement: paso 5, imagen 1 de 1
    • Carefully remove the separated back panel.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are unscrewed all the way before attempting again.
  6. Dell Studio 1555 RAM Replacement, RAM: paso 6, imagen 1 de 3 Dell Studio 1555 RAM Replacement, RAM: paso 6, imagen 2 de 3 Dell Studio 1555 RAM Replacement, RAM: paso 6, imagen 3 de 3
    • Press the tabs outwards to release the tabs. The memory stick is spring loaded and will be released at an angle.
  7. Dell Studio 1555 RAM Replacement: paso 7, imagen 1 de 1
    • Gently remove the memory stick from the slot.
  8. Dell Studio 1555 RAM Replacement: paso 8, imagen 1 de 2 Dell Studio 1555 RAM Replacement: paso 8, imagen 2 de 2
    • Once the first memory stick is removed, press the tabs outwards to release the tabs. The memory stick is spring loaded and will be released at an angle.
  9. Dell Studio 1555 RAM Replacement: paso 9, imagen 1 de 2 Dell Studio 1555 RAM Replacement: paso 9, imagen 2 de 2
Conclusión
3 personas más completaron esta guía.
Josh Boone
Miembro Desde 10/10/16
586 Reputación
4 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 1,211
