Saltar al contenido principal
Dell Studio 1555 Keyboard Replacement
Qué necesitas
  1. Dell Studio 1555 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Studio 1555 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Studio 1555 Keyboard Replacement: paso 2, imagen 3 de 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Keyboard Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
  5. Dell Studio 1555 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Studio 1555 Keyboard Replacement: paso 5, imagen 2 de 2
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
  6. Dell Studio 1555 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Studio 1555 Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
  7. Dell Studio 1555 Keyboard Replacement: paso 7, imagen 1 de 1
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
  8. Dell Studio 1555 Keyboard Replacement: paso 8, imagen 1 de 3 Dell Studio 1555 Keyboard Replacement: paso 8, imagen 2 de 3 Dell Studio 1555 Keyboard Replacement: paso 8, imagen 3 de 3
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
  9. Dell Studio 1555 Keyboard Replacement: paso 9, imagen 1 de 1
    • Remove the keyboard
Conclusión
2 personas más completaron esta guía.
Hunter Tuck
Miembro Desde 10/10/16
214 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 966
