Saltar al contenido principal
Partes
No se especificaron partes.
  1. Slide the battery release latch until it clicks into place.
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • CAUTION: Do not touch the processor thermal-cooling assembly. Processor components should be removed only by trained support personnel.
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 10
