Partes
No se requieren partes.
  1. Slide the battery release latch until it clicks into place.
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • CAUTION: Do not touch the processor thermal-cooling assembly. Processor components should be removed only by trained support personnel.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the four screws securing the hard drive assembly to the computer.
    • Remove the four screws securing the hard drive assembly to the computer.
    • Pull the hard drive cable pull-tab to disconnect the cable from the system board connector.
    • Pull on the hard drive pull-tab to lift the hard drive assembly from the bay.
  5. Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
  6. Disconnect the hard drive cable from the connector on the hard drive..
    • Disconnect the hard drive cable from the connector on the hard drive..
    • NOTICE: When the hard drive is not in the computer, store it in protective antistatic packaging. For more information, see "Protecting Against Electrostatic Discharge" in the safety information that shipped with your computer.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 8
