Saltar al contenido principal
Partes
No se especificaron partes.
  1. Slide the battery release latch until it clicks into place.
    • Slide the battery release latch until it clicks into place.
    • Turn the computer top side up, open the display, and press the power button to ground the system board.
  2. Turn the computer top side up, open the display, and press the power button to ground the system board.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Remove the four screws securing the hard drive assembly to the computer.
    • Remove the four screws securing the hard drive assembly to the computer.
    • Pull the hard drive cable pull-tab to disconnect the cable from the system board connector.
    • Pull on the hard drive pull-tab to lift the hard drive assembly from the bay.
  5. Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Remove the four M3 x 3-mm screws securing the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
  6. Disconnect the hard drive cable from the connector on the hard drive..
    • Disconnect the hard drive cable from the connector on the hard drive..
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 8
Todo El Tiempo: 96
