Qué necesitas
Slide the battery release latch until it clicks into place.
Slide the battery out of the battery bay.
Turn the computer over and open the display.
Ease the keyboard surround up using your fingers or a plastic scribe.
Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
Lift the keyboard off the computer.
Remove the four screws securing the hard drive assembly to the computer base.
Pull the black pull-tab to lift the hard drive assembly out of the computer base and disconnect the interposer from the SATA connector on the system board.
