Saltar al contenido principal
Dell Streak 7 Motherboard Replacement
Qué necesitas
  1. Dell Streak 7 Motherboard Replacement, Front Panel Assembly: paso 1, imagen 1 de 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Motherboard Replacement: paso 3, imagen 1 de 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Motherboard Replacement: paso 4, imagen 1 de 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Motherboard Replacement: paso 5, imagen 1 de 2 Dell Streak 7 Motherboard Replacement: paso 5, imagen 2 de 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Motherboard Replacement: paso 6, imagen 1 de 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Motherboard Replacement: paso 7, imagen 1 de 2 Dell Streak 7 Motherboard Replacement: paso 7, imagen 2 de 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Motherboard Replacement, Headphone Jack: paso 8, imagen 1 de 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Motherboard Replacement: paso 9, imagen 1 de 2 Dell Streak 7 Motherboard Replacement: paso 9, imagen 2 de 2
    • Pull the headphone jack up, away from the case.
  10. Dell Streak 7 Motherboard Replacement, GSM Module: paso 10, imagen 1 de 2 Dell Streak 7 Motherboard Replacement, GSM Module: paso 10, imagen 2 de 2
    • With the spudger, disconnect the antenna cable located on the module.
  11. Dell Streak 7 Motherboard Replacement: paso 11, imagen 1 de 2 Dell Streak 7 Motherboard Replacement: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, remove the tape connected to the GSM module.
  12. Dell Streak 7 Motherboard Replacement: paso 12, imagen 1 de 2 Dell Streak 7 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
  13. Dell Streak 7 Motherboard Replacement: paso 13, imagen 1 de 1
    • Disconnect the GSM module by lifting the module up, out of the case.
  14. Dell Streak 7 Motherboard Replacement, Motherboard: paso 14, imagen 1 de 3 Dell Streak 7 Motherboard Replacement, Motherboard: paso 14, imagen 2 de 3 Dell Streak 7 Motherboard Replacement, Motherboard: paso 14, imagen 3 de 3
    • Using the spudger, disconnect the front camera by lifting up on the connector.
  15. Dell Streak 7 Motherboard Replacement: paso 15, imagen 1 de 1
    • Using the Torx screwdriver, remove the six 3mm screws .
  16. Dell Streak 7 Motherboard Replacement: paso 16, imagen 1 de 2 Dell Streak 7 Motherboard Replacement: paso 16, imagen 2 de 2
    • Lift up the metal cover.
  17. Dell Streak 7 Motherboard Replacement: paso 17, imagen 1 de 1
    • Use the spudger to lift the vibration motor out of the case.
  18. Dell Streak 7 Motherboard Replacement: paso 18, imagen 1 de 1
    • Pull out the motherboard and the battery.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team 4-6, Passmore Fall 2016 Miembro de USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Miembros
12 Guías creadas
Un comentario
do you know any website or if you guys even sell the board to him
leonardo_hitman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 329
