Saltar al contenido principal
Dell Streak 7 Headphone Jack Replacement
Qué necesitas
  1. Dell Streak 7 Headphone Jack Replacement, Front Panel Assembly: paso 1, imagen 1 de 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Headphone Jack Replacement: paso 4, imagen 1 de 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Headphone Jack Replacement: paso 5, imagen 1 de 2 Dell Streak 7 Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Headphone Jack Replacement: paso 7, imagen 1 de 2 Dell Streak 7 Headphone Jack Replacement: paso 7, imagen 2 de 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Headphone Jack Replacement, Headphone Jack: paso 8, imagen 1 de 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Headphone Jack Replacement: paso 9, imagen 1 de 2 Dell Streak 7 Headphone Jack Replacement: paso 9, imagen 2 de 2
    • Pull the headphone jack up, away from the case.
Conclusión
Una persona más ha completado esta guía.
Ali Benjelloun
Miembro Desde 10/02/16
376 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 4-6, Passmore Fall 2016 Miembro de USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 152
