Saltar al contenido principal
Dell Precision M6800 Keyboard Replacement
Qué necesitas
  1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: paso 1, imagen 1 de 1
    • Replacing Dell Precision M6800's keyboard
  2. Dell Precision M6800 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Precision M6800 Keyboard Replacement: paso 2, imagen 2 de 2
    • Before any repair, you should remove battery
  3. Dell Precision M6800 Keyboard Replacement: paso 3, imagen 1 de 1
    • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
  4. Dell Precision M6800 Keyboard Replacement: paso 4, imagen 1 de 1
    • Unscrew 4 fastening screws which are at bottom of keyboard
  5. Dell Precision M6800 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Precision M6800 Keyboard Replacement: paso 5, imagen 2 de 2
    • Pry out four hooks which are on the sides of keyboard (two per one site)
    • Be carefull to not break of hooks - use constant force and do it slowly
  6. Dell Precision M6800 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Precision M6800 Keyboard Replacement: paso 6, imagen 2 de 2
    • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
    • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
  7. Dell Precision M6800 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Precision M6800 Keyboard Replacement: paso 7, imagen 2 de 2
    • Pry up the white part of connector (constant for both sides) and eject connecting flex
Conclusión
4 personas más completaron esta guía.
Szymon Milewski
Miembro Desde 12/28/20
741 Reputación
3 Guías creadas
2 comentarios
Great job, thank you
kali1902 - Contestar
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 1,228
