Saltar al contenido principal
Dell Precision M6600 Hard Drive Replacement
Qué necesitas
  1. Dell Precision M6600 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: paso 2, imagen 1 de 2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: paso 2, imagen 2 de 2
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: paso 3, imagen 1 de 2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: paso 3, imagen 2 de 2
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: paso 4, imagen 1 de 1
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
Conclusión
4 personas más completaron esta guía.
Kaley lindsay
Miembro Desde 03/23/18
582 Reputación
4 Guías creadas
Equipo
Un comentario
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 30
Todo El Tiempo: 3,670
