Saltar al contenido principal
Partes
No se especificaron partes.
  1. Slide the release latch to unlock the battery. Flip and remove the battery from the computer.
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover. Flip and remove the base cover from the computer.
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Pry up the keyboard trim starting from the top-inner edge. Pry up the bottom edge of the keyboard trim from the top-inner edge.
    • Pry up the keyboard trim starting from the top-inner edge.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge.
  5. Remove the screws that secure the keyboard to the computer. Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over. Disconnect the keyboard-data cable from the system board and remove the keyboard.
    • Remove the screws that secure the keyboard to the computer.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board and remove the keyboard.
  6. Flip Computer To its Back.
    • Flip Computer To its Back.
    • Pry the retention clips away from the memory module until it pops up. Lift up the memory module and remove it from the computer.
  7. Flip the Computer To its Top.
    • Flip the Computer To its Top.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 12
Todo El Tiempo: 210
