Partes
No se requieren partes.
  1. Slide the release latch to unlock the battery. Flip and remove the battery from the computer.
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover. Flip and remove the base cover from the computer.
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the screws that secure the hard drive to the computer. Slide the hard -drive latch to the unlock position and pull out the hard drive from the computer.
    • Remove the screws that secure the hard drive to the computer. Slide the hard -drive latch to the unlock position and pull out the hard drive from the computer.
  5. Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
Conclusión
Una persona más ha completado esta guía.
Johnathan Hammond
Miembro Desde 28/02/18
35,756 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 27
Todo El Tiempo: 302
