Saltar al contenido principal
Partes
No se especificaron partes.
  1. Slide the battery release latches toward each other to lock them in an open position.
    • Slide the battery release latches toward each other to lock them in an open position.
    • Slide the battery out of the battery bay.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Loosen the captive screw.
    • Loosen the captive screw.
    • Slide the bottom of the base assembly away from the hinge covers, and lift to remove the bottom of the base assembly.
  4. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
Conclusión
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 24
