Saltar al contenido principal
Dell Precision 7560 Touchpad Replacement
Qué necesitas
  1. Dell Precision 7560 Touchpad Replacement, Battery: paso 1, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement, Battery: paso 1, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement, Battery: paso 1, imagen 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Touchpad Replacement: paso 2, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 2, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 2, imagen 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Touchpad Replacement: paso 3, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 3, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 3, imagen 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Touchpad Replacement, Speaker: paso 4, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement, Speaker: paso 4, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement, Speaker: paso 4, imagen 3 de 3
    • Loosen the eight captive screws that secure the fan assembly using a Phillips #0 screwdriver.
    • Lifting from the bottom, carefully remove the fan.
  5. Dell Precision 7560 Touchpad Replacement: paso 5, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 5, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 5, imagen 3 de 3
    • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Remove the metal overlay.
    • Disconnect the wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card.
  6. Dell Precision 7560 Touchpad Replacement: paso 6, imagen 1 de 2 Dell Precision 7560 Touchpad Replacement: paso 6, imagen 2 de 2
    • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
    • Remove, carefully and completely, any wires running over the frame.
    • Lift the metal frame.
  7. Dell Precision 7560 Touchpad Replacement: paso 7, imagen 1 de 2 Dell Precision 7560 Touchpad Replacement: paso 7, imagen 2 de 2
    • Flip up the metal edge holding down the SD connection.
    • Gently pull to disconnect the metal connecting wire.
  8. Dell Precision 7560 Touchpad Replacement: paso 8, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 8, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 8, imagen 3 de 3
    • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
    • Remove the metal cap.
    • Disconnect the wire bundle.
  9. Dell Precision 7560 Touchpad Replacement: paso 9, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 9, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 9, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
    • Carefully remove the speaker wire from the motherboard.
  10. Dell Precision 7560 Touchpad Replacement: paso 10, imagen 1 de 2 Dell Precision 7560 Touchpad Replacement: paso 10, imagen 2 de 2
    • Using both hands, carefully lift and remove the speaker.
  11. Dell Precision 7560 Touchpad Replacement, Touchpad: paso 11, imagen 1 de 2 Dell Precision 7560 Touchpad Replacement, Touchpad: paso 11, imagen 2 de 2
    • Gently remove and disconnect the connecting strip from the touchpad.
    • Remove the two 2 mm screws using a Phillips #0 screwdriver.
    • Remove the black tab from the bottom of the touchpad.
  12. Dell Precision 7560 Touchpad Replacement: paso 12, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 12, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 12, imagen 3 de 3
    • Lift up the white connecting strip with your finger.
    • Using a Phillips #0 screwdriver, remove the two 2 mm screws.
    • Remove the metal bracket.
  13. Dell Precision 7560 Touchpad Replacement: paso 13, imagen 1 de 2 Dell Precision 7560 Touchpad Replacement: paso 13, imagen 2 de 2
    • Detach the blue and white connecting tab using an opening tool.
  14. Dell Precision 7560 Touchpad Replacement: paso 14, imagen 1 de 3 Dell Precision 7560 Touchpad Replacement: paso 14, imagen 2 de 3 Dell Precision 7560 Touchpad Replacement: paso 14, imagen 3 de 3
    • Warm all sides of the touch pad using an iOpener to loosen the glue.
    • Lift the warmed up sides with a metal spudger.
  15. Dell Precision 7560 Touchpad Replacement: paso 15, imagen 1 de 2 Dell Precision 7560 Touchpad Replacement: paso 15, imagen 2 de 2
    • Use your fingers to take out the touchpad.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 24
Todo El Tiempo: 193
