Saltar al contenido principal
Dell Precision 7560 Solid-State Drive (SSD) Replacement
Qué necesitas
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: paso 1, imagen 1 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: paso 1, imagen 2 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: paso 1, imagen 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 2, imagen 1 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 2, imagen 2 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 2, imagen 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 3, imagen 1 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 3, imagen 2 de 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 3, imagen 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): paso 4, imagen 1 de 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): paso 4, imagen 2 de 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 5, imagen 1 de 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: paso 5, imagen 2 de 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
Conclusión
Hector
Miembro Desde 02/14/23
261 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 43
Todo El Tiempo: 800
