Saltar al contenido principal
Dell Precision 7560 Screen Replacement
Qué necesitas
  1. Dell Precision 7560 Screen Replacement, Screen: paso 1, imagen 1 de 3 Dell Precision 7560 Screen Replacement, Screen: paso 1, imagen 2 de 3 Dell Precision 7560 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: paso 2, imagen 1 de 2 Dell Precision 7560 Screen Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: paso 3, imagen 1 de 3 Dell Precision 7560 Screen Replacement: paso 3, imagen 2 de 3 Dell Precision 7560 Screen Replacement: paso 3, imagen 3 de 3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Conclusión
Laisha
Miembro Desde 02/14/23
202 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 44
Todo El Tiempo: 659
