Saltar al contenido principal
Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
Qué necesitas
  1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): paso 1, imagen 1 de 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): paso 1, imagen 2 de 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): paso 1, imagen 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: paso 2, imagen 1 de 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: paso 2, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
  3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: paso 3, imagen 1 de 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: paso 3, imagen 2 de 2
    • Disconnect the left SSD stick by pulling its exposed end towards you.
    • Repeat the same procedure to the right SSD stick.
Conclusión
Hector
Miembro Desde 02/14/23
261 Reputación
2 Guías creadas
Equipo
Un comentario
This is not for RAM this is for the SSD upgrades.
Kurtis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 49
Todo El Tiempo: 509
