Saltar al contenido principal
Dell Precision 7560 Keyboard Replacement
Qué necesitas
  1. Dell Precision 7560 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Precision 7560 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Precision 7560 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Precision 7560 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Precision 7560 Keyboard Replacement: paso 2, imagen 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: paso 3, imagen 1 de 3 Dell Precision 7560 Keyboard Replacement: paso 3, imagen 2 de 3 Dell Precision 7560 Keyboard Replacement: paso 3, imagen 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Precision 7560 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Precision 7560 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Precision 7560 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Precision 7560 Keyboard Replacement: paso 5, imagen 3 de 3
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: paso 6, imagen 1 de 3 Dell Precision 7560 Keyboard Replacement: paso 6, imagen 2 de 3 Dell Precision 7560 Keyboard Replacement: paso 6, imagen 3 de 3
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
Conclusión
2 personas más completaron esta guía.
Jack Allred
Miembro Desde 02/09/23
345 Reputación
2 Guías creadas
Equipo
Un comentario
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 53
Todo El Tiempo: 1,055
