Saltar al contenido principal
Dell Precision 7560 Battery Replacement
Qué necesitas
  1. Dell Precision 7560 Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell Precision 7560 Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell Precision 7560 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Battery Replacement: paso 2, imagen 1 de 3 Dell Precision 7560 Battery Replacement: paso 2, imagen 2 de 3 Dell Precision 7560 Battery Replacement: paso 2, imagen 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Battery Replacement: paso 3, imagen 1 de 3 Dell Precision 7560 Battery Replacement: paso 3, imagen 2 de 3 Dell Precision 7560 Battery Replacement: paso 3, imagen 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
Conclusión
Una persona más ha completado esta guía.
Laisha
Miembro Desde 02/14/23
205 Reputación
2 Guías creadas
Equipo
Un comentario
Was able to reset a battery that stopped charging with these instructions, appreciate it!
Emiline Doerr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 52
Ultimos 30 días: 149
Todo El Tiempo: 2,373
