Saltar al contenido principal
Dell Precision 5510 Hard Drive Replacement
Qué necesitas
  1. Dell Precision 5510 Hard Drive Replacement, Base Cover: paso 1, imagen 1 de 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Hard Drive Replacement, Battery: paso 3, imagen 1 de 2 Dell Precision 5510 Hard Drive Replacement, Battery: paso 3, imagen 2 de 2
    • Unplug the connection that links the battery to the computer.
  4. Dell Precision 5510 Hard Drive Replacement: paso 4, imagen 1 de 2 Dell Precision 5510 Hard Drive Replacement: paso 4, imagen 2 de 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  5. Dell Precision 5510 Hard Drive Replacement: paso 5, imagen 1 de 2 Dell Precision 5510 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Carefully remove the battery from the computer.
  6. Dell Precision 5510 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Dell Precision 5510 Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Remove the four 4.0 mm screws with a Phillips 1 screwdriver, and remove the hard drive bracket.
  7. Dell Precision 5510 Hard Drive Replacement: paso 7, imagen 1 de 1
    • Unplug the hard drive, and remove it. (We do not have a hard drive to be shown, but see image for where the hard drive would be unplugged from.)
Conclusión
Atlanta Phelps
Miembro Desde 08/28/18
400 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G5, Arle Fall 2018 Miembro de IUPUI, Team S1-G5, Arle Fall 2018
IUPUI-ARLE-F18S1G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 52
Todo El Tiempo: 3,773
