Saltar al contenido principal
Dell Precision 5510 Fans Replacement
Qué necesitas
  1. Dell Precision 5510 Fans Replacement, Base Cover: paso 1, imagen 1 de 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Fans Replacement: paso 2, imagen 1 de 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Fans Replacement, Fans: paso 3, imagen 1 de 2 Dell Precision 5510 Fans Replacement, Fans: paso 3, imagen 2 de 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Fans Replacement: paso 4, imagen 1 de 2 Dell Precision 5510 Fans Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Fans Replacement: paso 5, imagen 1 de 2 Dell Precision 5510 Fans Replacement: paso 5, imagen 2 de 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
Conclusión
Amelia Andrews
Miembro Desde 03/31/22
97 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-1, Harley Spring 2022 Miembro de IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 482
