Saltar al contenido principal
Dell Photo Printer 720 Encoder Strip Replacement
Qué necesitas
  1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: paso 1, imagen 1 de 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: paso 1, imagen 2 de 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: paso 1, imagen 3 de 3
    • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
  2. Dell Photo Printer 720 Encoder Strip Replacement: paso 2, imagen 1 de 3 Dell Photo Printer 720 Encoder Strip Replacement: paso 2, imagen 2 de 3 Dell Photo Printer 720 Encoder Strip Replacement: paso 2, imagen 3 de 3
    • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
    • Pry apart the light grey cover from the black base.
    • Gently flip the printer upright to its standard position and carefully lift off the cover.
  3. Dell Photo Printer 720 Encoder Strip Replacement: paso 3, imagen 1 de 2 Dell Photo Printer 720 Encoder Strip Replacement: paso 3, imagen 2 de 2
    • Slide the ink cartridge from the right side to the middle left so it is out of the way.
  4. Dell Photo Printer 720 Encoder Strip Replacement: paso 4, imagen 1 de 3 Dell Photo Printer 720 Encoder Strip Replacement: paso 4, imagen 2 de 3 Dell Photo Printer 720 Encoder Strip Replacement: paso 4, imagen 3 de 3
    • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
    • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
    • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
Conclusión
Una persona más ha completado esta guía.
Megan Lawrence
Miembro Desde 01/14/15
534 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 526
