Saltar al contenido principal
Dell Optiplex SX280 Motherboard Replacement
Qué necesitas
  1. Dell Optiplex SX280 Motherboard Replacement, Panel Cover: paso 1, imagen 1 de 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Motherboard Replacement: paso 2, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 2, imagen 2 de 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Motherboard Replacement: paso 3, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 3, imagen 2 de 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Motherboard Replacement, Heat Sink: paso 4, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement, Heat Sink: paso 4, imagen 2 de 2
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Dell Optiplex SX280 Motherboard Replacement: paso 5, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 5, imagen 2 de 2
    • Press down on the release tab above the heat sink.
  6. Dell Optiplex SX280 Motherboard Replacement: paso 6, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 6, imagen 2 de 2
    • Pull the heat sink out of the computer while pressing on the release tab.
    • When reassembling make sure to clean the processor and heat sink of all old thermal paste and apply new paste to the processor
  7. Dell Optiplex SX280 Motherboard Replacement, Upper Fan: paso 7, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement, Upper Fan: paso 7, imagen 2 de 2
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  8. Dell Optiplex SX280 Motherboard Replacement: paso 8, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove the rubber grommets from the base of the fan. A spudger may be useful.
  9. Dell Optiplex SX280 Motherboard Replacement: paso 9, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 9, imagen 2 de 2
    • Press on the blue release tab and pull the upper fan out of the computer.
  10. Dell Optiplex SX280 Motherboard Replacement, Lower Fan: paso 10, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement, Lower Fan: paso 10, imagen 2 de 2
    • Remove the power supply that connects the lower fan to the motherboard, distinguished by it's black, red, green and yellow wires.
    • Make sure to press on the release tab while removing the power connector.
  11. Dell Optiplex SX280 Motherboard Replacement: paso 11, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 11, imagen 2 de 2
  12. Dell Optiplex SX280 Motherboard Replacement: paso 12, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 12, imagen 2 de 2
    • Press on the blue release tab and remove the fan.
  13. Dell Optiplex SX280 Motherboard Replacement, RAM: paso 13, imagen 1 de 1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  14. Dell Optiplex SX280 Motherboard Replacement: paso 14, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 14, imagen 2 de 2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
  15. Dell Optiplex SX280 Motherboard Replacement, Hard Drive: paso 15, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement, Hard Drive: paso 15, imagen 2 de 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  16. Dell Optiplex SX280 Motherboard Replacement: paso 16, imagen 1 de 1
    • Unplug the power supply, distinguished by its red and yellow wires.
  17. Dell Optiplex SX280 Motherboard Replacement: paso 17, imagen 1 de 1
    • Squeeze the release tabs on either side of the hard drive.
    • Then slide the hard drive out of the computer while squeezing the tabs.
  18. Dell Optiplex SX280 Motherboard Replacement, Motherboard: paso 18, imagen 1 de 1
    • Unplug the cable that connects the hard drive to the Motherboard.
  19. Dell Optiplex SX280 Motherboard Replacement: paso 19, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 19, imagen 2 de 2
    • Press on the release tab and remove the motherboard speaker which is attached to the side of the tower.
  20. Dell Optiplex SX280 Motherboard Replacement: paso 20, imagen 1 de 1
    • Unplug the power cable attached to the motherboard speaker.
    • Make sure to press on the release tab while removing the power cable.
  21. Dell Optiplex SX280 Motherboard Replacement: paso 21, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 21, imagen 2 de 2
    • Remove four screws located at the back of the computer tower.
  22. Dell Optiplex SX280 Motherboard Replacement: paso 22, imagen 1 de 1
    • Carefully detach the motherboard from the computer case.
  23. Dell Optiplex SX280 Motherboard Replacement: paso 23, imagen 1 de 1
    • Lift the motherboard from the rest of the computer case.
  24. Dell Optiplex SX280 Motherboard Replacement: paso 24, imagen 1 de 1
    • Unplug the cable that powers the hard drive, which has orange, red and yellow wires.
    • Make sure to press the release tab while removing the cable.
  25. Dell Optiplex SX280 Motherboard Replacement: paso 25, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 25, imagen 2 de 2
    • Unplug the cable that powers the emergency shut off, distinguished by its red wires.
    • Make sure to press on the release tab while removing the emergency shut off.
  26. Dell Optiplex SX280 Motherboard Replacement: paso 26, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 26, imagen 2 de 2
    • Remove two screws from the Hard Drive Stand.
  27. Dell Optiplex SX280 Motherboard Replacement: paso 27, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 27, imagen 2 de 2
    • Slide the Hard Drive Stand to left side.
    • Remove the stand from the rest of the rear panel.
  28. Dell Optiplex SX280 Motherboard Replacement: paso 28, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 28, imagen 2 de 2
    • Remove the studs that support the Hard Drive Stand from the motherboard.
    • The studs can be removed by hand.
  29. Dell Optiplex SX280 Motherboard Replacement: paso 29, imagen 1 de 3 Dell Optiplex SX280 Motherboard Replacement: paso 29, imagen 2 de 3 Dell Optiplex SX280 Motherboard Replacement: paso 29, imagen 3 de 3
    • Remove the four screws located on heat sink stand.
    • The heat sink stand can now be lifted from the motherboard.
  30. Dell Optiplex SX280 Motherboard Replacement: paso 30, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 30, imagen 2 de 2
    • Remove the four screws holding the motherboard to the rear computer panel.
  31. Dell Optiplex SX280 Motherboard Replacement: paso 31, imagen 1 de 2 Dell Optiplex SX280 Motherboard Replacement: paso 31, imagen 2 de 2
    • The motherboard can now be removed from the remaining panel.
Conclusión
11 personas más completaron esta guía.
Tom
Miembro Desde 10/04/10
841 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 22-4, Maness Fall 2010 Miembro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Miembros
26 Guías creadas
2 comentarios
Good job. Thanks for sharing, friend.
Angel Peguero - Contestar
Great guide! I got stuck at the Mobo tray, I knew the black screws were involved but couldn't get it with out help. Thanks!
Fans can be removed with board tray, otherwise they're getting pulled off their rubber isolating feet. Once out with the mobo, the fans slide off the board tray with their plastic shoes attached.
purchases - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 19,158
