Saltar al contenido principal
Dell Optiplex SX280 Lower Fan Replacement
Qué necesitas
  1. Dell Optiplex SX280 Lower Fan Replacement, Panel Cover: paso 1, imagen 1 de 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Lower Fan Replacement: paso 2, imagen 1 de 2 Dell Optiplex SX280 Lower Fan Replacement: paso 2, imagen 2 de 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Lower Fan Replacement: paso 3, imagen 1 de 2 Dell Optiplex SX280 Lower Fan Replacement: paso 3, imagen 2 de 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: paso 4, imagen 1 de 2 Dell Optiplex SX280 Lower Fan Replacement, Lower Fan: paso 4, imagen 2 de 2
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Dell Optiplex SX280 Lower Fan Replacement: paso 5, imagen 1 de 1
    • Remove the power supply by pressing the release tab. It is distinguished by the black, red, green, and yellow wires.
  6. Dell Optiplex SX280 Lower Fan Replacement: paso 6, imagen 1 de 2 Dell Optiplex SX280 Lower Fan Replacement: paso 6, imagen 2 de 2
    • Remove the rubber grommets from the base of the fan. The iFixit Opening tool may be useful in this step.
  7. Dell Optiplex SX280 Lower Fan Replacement: paso 7, imagen 1 de 2 Dell Optiplex SX280 Lower Fan Replacement: paso 7, imagen 2 de 2
    • Press on the blue release tab and remove the fan.
Conclusión
3 personas más completaron esta guía.
Tom
Miembro Desde 10/04/10
841 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 22-4, Maness Fall 2010 Miembro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 4,182
